MText object
Class AcadMText
Member of BricscadDb
The MText object represents multi-line text, or a paragraph of characters that fits within a boundary. To create an MText object, use the AddMText or method. To modify or obtain information about a point entity, use the following methods and properties:
Methods Properties Events
ArrayPolar Application Modified
ArrayRectangular AttachmentPoint
Copy BackgroundFill
Delete Document
GetBoundingBox DrawingDirection
GetExtensionDictionary Handle
GetXData HasExtensionDictionary
Highlight Height
IntersectWith Hyperlinks
Mirror InsertionPoint
Mirror3D Layer
Move Linetype
Rotate LinetypeScale
Rotate3D Lineweight
ScaleEntity Normal
SetXData Parent
TransformBy PlotStyleName
Update Rotation
  StyleName
  TextString
  Visible
  Width
