Class AcadPolyfaceMesh
Member of BricscadDb
The PolyfaceMesh object is a 3D mesh consisting of a series of connected polygon faces. To create a PolyfaceMesh object, use the AddPolyfaceMesh method. To access a PolyfaceMesh object, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Coordinate |
Copy | Coordinates |
Delete | Document |
GetBoundingBox | Handle |
GetExtensionDictionary | HasExtensionDictionary |
GetWidth | Hyperlinks |
GetXData | Layer |
Highlight | Linetype |
IntersectWith | LinetypeScale |
Mirror | Lineweight |
Mirror3D | Material |
Move | NumberOfFaces |
Offset | NumberOfVertices |
Rotate | ObjectID |
Rotate3D | ObjectName |
ScaleEntity | OwnerID |
SetXData | PlotStyleName |
TransformBy | TrueColor |
Update | Visible |
© Menhirs NV. All rights reserved. |
