To make a Network license available in BricsCAD on client computers, a network license server from Reprise Software needs to be installed first by the network administrator.
The Bricsys Network License Manager is a separate program which will install the server.
After starting the network license server, it can be completely configured by using a web interface.
Just like BricsCAD needs a license file to run, the server also needs a Network license file that can be activated online or manually.
A Network license can only be activated once and it is locked to the server.
Once the Network license is activated and the server is started, it is possible to use the Network license in BricsCAD, on a client computer.
Related topics
Windows network license server setup
Linux network license server setup
RLM License Administration Manual
