Deletes duplicate entities and overlapping lines, arcs or polylines and unifies partly overlapping or contiguous ones.
command bar: overkill
: overkill
Select entities: (Compose a selection set, then press Enter.)
Entity properties to ignore |
Selected properties are ignored when comparing duplicate or overlapping entities. |
Comparison tolerance |
Sets the tolerance for the comparison process. If set to 0 (zero), entities must match completely before being evaluated in the overkill process. |
Options |
If checked:
-Overkill - deletes duplicate entities and overlapping lines, arcs or polylines and unifies partly overlapping or contiguous ones; prompts you in the command bar.
Break - erases a portion of an entity.
Erase - erases entities from the drawing.
Join - joins lines, LW polylines, 2D polylines, 3D polylines, circular arcs, elliptical arcs, splines and helixes at their common endpoints.
Oops - returns erased entities.
Purge - removes unused named entities from drawings, such as unused layers and linetypes.
Trim - removes portions of entities.
U - unerases erased entities.
Undo - unerases erased entities.
© Menhirs NV. All rights reserved. |
