Trim
Trims entities to a cutting line.
command bar:  trim
alias:  tr
menu bar:  Modify | Trim
toolbar:  Modify |
: trim
Select cutting entities for trim <ENTER to select all>: (Choose one or more entities, or press Enter to select all entities in the drawing.)
Entities in set: 1
Select cutting entities for trim <ENTER to select all>: (Press Enter to continue the command.)
Fence/Crossing/Edge mode/Projection/eRase/<Select entity to trim or shift-select to extend>: (Pick an entity or enter an option or press shift, then pick an entity to extend)
Fence/Crossing/Edge mode/Projection/eRase/Undo/<Select entity to trim or shift-select to extend>: (Pick another entity or press shift, then pick an entity to extend.)
Fence/Crossing/Edge mode/Projection/eRase/Undo/<Select entity to trim or shift-select to extend>:: (Press Enter to exit command.)
Shift key
Extends the picked entities instead of trimming them. When executing the Trim or the Extend command, pressing the shift key switches between trimming and extending.
Choose one or more entities to act as cut lines, including text.
These entities define where crossing entities are trimmed.
Select one or more entities using any selection method.
ENTER to select all
Selects all entities in the drawing, except for those on frozen layers.
Press Enter to select all.
Note that entities can both define cutlines and be cut.
Chooses the entity to be trimmed.
Select a single entity; only one entity can be trimmed at a time.
Your pick point defines the portion of the entity to be removed.
Edge mode
Toggles edge mode; prompts you:
Extend/No extend - type E or N.
  • Extend - trims entities that do not physically intersect the cutting entity.
  • No extend - trim only entities that intersect.
See Projection option.
Fence
Cuts entities interactively; prompts you:
First point of fence - specify the fence's starting point.
Next fence point - specify the next point; press Enter to exit this option.
As you pick fence points in the drawing, BricsCAD immediately trims entities under the fence.
The portion of each entity between other entities is trimmed:
Use this option together with ALL (select all entities to trim).
Crossing
First corner of crossing window - specify the first corner
Second corner of crossing window - specify the second corner.
The portions of the entities that cross the specified rectangle are trimmed.
Projection
Defines how intersections are projected; prompts you:
None/Ucs/View - enter an option.
This option affects the operation of the Edge option.
None
Intersections are not projected.
Only those entities that intersect are trimmed.
UCS
Intersections are projected into the x,y plane of the current UCS.
Entities that appear to intersect are trimmed.
View
Intersections are projected along the current viewpoint.
Erase
Deletes selected entities; prompts you:
Select entities to delete - select the entities
Undo
Undoes the last trim action.
Repeat this option undo earlier trim actions.
Procedures
To trim entities
Break - cuts parts out of entities.
Chamfer - chamfers intersections.
Extend - Extends open entities to a boundary.
Fillet - fillets intersections.
Settings - specifies parameters for trims.
