Selects one or more entities; can be accessed later with the Previous option.
command bar: select
shortcut: Ctrl+A selects all entities on non-frozen layers
: select
Select entities to include in set: (Choose one or more entities using any selection mode, listed below.)
Select entities to include in set: (Choose more entities, or press Enter to exit command.)
You can use any selection mode (listed below) at the 'Select entities' prompt found in many editing commands.
Abbreviation |
Chooses entities. You can use any of the following selection options: |
All |
ALL |
Selects all entities in the drawing, except for those on frozen layers. |
Window |
W |
Selects all entities fully inside a rectangular selection window; prompts you: First corner of inclusive window - specify the first point of the selection rectangle. Opposite corner - specify the other corner.
Crossing |
C |
Selects all entities inside and crossing a rectangular selection window; prompts you: First corner of crossing window - specify the first point of the selection rectangle. Opposite corner - specify the other corner.
Outside |
O |
Selects all entities fully outside a rectangular selection window; prompts you: First corner of exclusive window - specify the first point of the selection rectangle. Opposite corner - specify the other corner.
Window polygon |
WP |
Selects all entities fully inside a polygonal selection window; prompts you: First vertex of inclusive polygon - specify the first point of the selection polygon. Next vertex - specify the next point. Next vertex - press Enter to close the vertex.
Crossing polygon |
CP |
Selects all entities inside and crossing a polygonal selection window; prompts you: First vertex of crossing polygon - specify the first point of the selection polygon. Next vertex - specify the next point. Next vertex - press Enter to close the vertex.
Outside polygon |
OP |
Selects all entities fully outside a polygonal selection window; prompts you: First vertex of outside polygon - specify the first point of the selection polygon. Next vertex - specify the next point. Next vertex - press Enter to close the vertex.
Window circle |
WC |
Selects all entities fully inside a circular selection window; prompts you: Center of circle - pick a center point. Radius of circle - specify a radius by picking or entering a value
Crossing circle |
CC |
Selects all entities inside and crossing a circular selection window; prompts you: Center of circle - pick a point. Radius of circle - specify a radius by picking or entering a value.
Outside circle |
OC |
Selects all entities fully outside a circular selection window; prompts you: Center of circle - pick a point. Radius of circle - specify a radius by picking or entering a value.
Point |
PO |
Selects all closed entities surrounding the pick point; prompts you: Point to locate entity around - specify a point.
Fence |
F |
Selects all entities that cross the fence selection lines; prompts you: First point of fence - specify the starting point of the fence. Next vertex - specify the next point. Next vertex - press Enter to finish drawing the fence.
Previous |
P |
Reuses the entities selected with the previous selection. |
Last |
L |
Selects the last entity drawn. |
Add |
A |
Adds additional entities to the selection set; prompts you: Select entities to include in set - add entities to the selection set. This option is typically used following the Subtract option. |
Subtract |
R |
Removes entities from the selection set; prompts you: Subtract entities from selection set - remove entities from the selection set. |
Undo |
U |
Undoes the last action during this command. |
Group |
G |
Selects a group; Prompts you: Enter group name - type the name of a group. |
Settings |
D |
Displays the Entity Selection section of the Settings dialog box.
Properties |
PRO |
Selects entities on the basis of their properties; prompts you: Select by properties - enter a property mode. See Properties command. |
Color |
C |
Selects all entities of the same color; prompts you: Color to select - specify a color number or name. See Color command. |
Layer |
LA |
Selects all entities of the same layer names; prompts you: Layer name(s) to select - specify one or more layer names. Use commas to separate multiple layer names. See Layer command. |
Linetype |
LI |
Selects all entities of the same linetype; prompts you: Linetype(s) to select - specify one or more linetype names. Use commas to separate multiple linetype names. See Linetype command. |
Name |
N |
Selects all entities of the same entity name; prompts you: Entity name(s) to select - specify one or more entity names. Use commas to separate multiple entity names. Entity names are the names of entities, such as line, circle, arc, and ray. |
Thickness |
TH |
Selects all entities of the same thickness; prompts you: Thickness to select - enter a number. See Elev command. |
Value |
V |
Selects all entities with the same value; prompts you: Value(s) to select - enter one or more values. Use commas to separate multiple entity values. |
Width |
W |
Selects all entities of the same width; prompts you: Width to select - enter a number. |
Handle |
H |
Select the entity with the handle number; prompts you: Entity handle to select - enter a number, such as 889. Handles are hexadecimal numbers that uniquely identify every entity in drawings. To determine the handle number, use the List command. |
Location |
LO |
Returns to the original prompt: Select entities to include in set - add entities to the selection set. |
Procedures
Composing a selection set before (pre-pick)
Composing a selection set afterwards (post-pick)
Selecting overlapping entities
To create a selection set using QuickSelect
DdSelect - sets selection properties in the Entity Selection section of the Settings dialog box.
SelectSimilar - selects all entities of the same type as the current selection, based on a set of matching properties, stored in the SELECTSIMILARMODE system variable
SelGrips - selects entities and displays grips.
QSelect - composes a selection set using filters.
