Chamfer
Creates chamfers; adds an angle to intersections.
command bar:  chamfer
alias:  cha
menu bar:  Modify | Chamfer
toolbar:  Modify |
: chamfer
Chamfer (dist1=0.5000, dist2=0.5000):  Settings/Polyline/Angle/Distance/mEthod/Trim/Undo/Multiple/<Select first entity>:  (Select an entity, or enter an option.)
Select second entity: (Select another entity.)
Chamfered intersection.
Chamfered polyline.
Select first entity
Selects the first entity to be chamfered.
Only open entities can be chamfered, with one exception: vertices of closed polylines can be chamfered with the Polyline option.
This command cannot place a chamfer between two polylines,but it can place a chamfer between a line and a polyline, even a closed polyline.
Selects the second entity.
The two entities need not meet, but cannot be parallel to each other.
Settings
Displays the Settings dialog box for changing chamfer parameters.
Polyline
Chamfers the vertices of a polyline; prompts you:
Select 2D polyline to chamfer: (Select a polyline with at least one vertex.)
Angle
Prompts you for the Chamfer length and Chamfer angle in the command bar and sets the Chamfer mode to Length-Angle.
Distance
Prompts you for the Chamfer first distance and Chamfer second distance in the command bar and sets the Chamfer mode to Distance-Distance.
Method
Prompts you to set the Chamfer mode in the command bar. The options are: Angle or Distance.
Trim
Prompts you to set the Trim mode in the command bar.
Undo
Undoes the last chamfer when in Multiple mode.
Multiple
Lets you create multiple chamfers using the same settings.
Settings
Setting
Chamfer Mode
Determines how the chamfer is created:
  • Distance-Distance - specify two distances.
  • Length-Angle - specify length and angle.
Chamfer First Distance
Specifies the default value of the first chamfer distance.
Chamfer Second Distance
Specifies the default value of the first second distance.
Chamfer Length
Specifies the default length of the chamfer.
Chamfer Angle
Specifies the default angle of the chamfer.
Trim Mode
Toggles whether intersecting entities are trimmed:
  • Yes - trims intersecting entities back to the chamfer.
  • No - does not trim intersecting entities.
Procedures
Chamfering using the distance-distance method
Chamfering using the length-angle method
Chamfering all vertices of a polyline
Break - cuts parts out of entities.
Fillet - fillets intersections.
Settings - specifies parameters for chamfers.
SolidEdit - edits faces, edges, and bodies of solid models.
Trim - trims entities where they cross other entities.
