Command: PROFILEMANAGER
In BricsCAD you can customize the settings that control your drawing environment, which can then be saved in a user profile. You can create multiple user profiles, e.g. a profile to run BricsCAD with a white background and a limited set of toolbars and another profile with no command bar and all toolbars and snap settings needed to draw comfortably in 3D. User profiles can also be used when multiple users share the same computer and each user likes to create his personal drawing environment.
User profiles can be saved to a file, which can then be imported on a different computer. This allows you to copy your settings to a new computer or to install the same settings on multiple computers.
If you use a third party applications on top of BricsCAD, you might want to create a user profile to use with each of these applications.
The User Profile Manager is a standalone tool that lists the existing profiles and provides all the tools needed to Load, Create, Set Current, Copy, Rename, Delete, Export and Import user profiles.
User profiles save many settings that control the drawing environment. Once you start BricsCAD using a user profile, it automatically tracks and stores changes that you make to your drawing environment.
Main Cui file.
Configuration settings: all system variables which are saved in
the Registry (
) and user preferences.
Default plot settings.
Settings in dialog windows, e.g. search options in the Settings dialog.
Project settings
Recent paths
Status bar settings
Properties Bar settings
Toolbar and menu configuration
To Launch the User Profile Manager
Do one of the following:
When BricsCAD is running: choose User Profile Manager in the Tools menu.
From the Windows Start menu, choose All Programs > Bricsys > BricsCAD > User Profile Manager.
Double click userprofilemanager.exe in the BricsCAD program folder (e.g. C:\Program Files\Bricsys\BricsCAD Vx).
In the User Profile Manager dialog:
To create a new user profile:
Launch the User Profile Manager.
Click the Create button on the
window.
The Create Profile dialog opens.
Type a name for the new profile in the Profile name field.
(option) Type a description for the new profile in the Description field.
Click the OK button to create the
profile.
The new profile is added in the available profiles list.
The new profile is created using default hard-coded values for all
settings.
NOTE |
Use the Copy option to create a new user profile as a copy of an existing profile. |
Starting BricsCAD with a specific user profile
When you start BricsCAD, the user profile that was current when you closed the previous BricsCAD session is used.
To launch BricsCAD using a specific user profile, do one of the following:
Add the /P option to the
Target settings of the BricsCAD
shortcut.
To open the shortcut settings dialog: right click the shortcut icon
on the desktop and choose Properties
in the context menu.
A typical BricsCAD shortcut could be "C:\Program Files\Bricsys\BricsCAD Vx\bricscad.exe" /P
<UserProfileName>
Launch the User Profile Manager, then either double click a user profile or select a user profile and click the Start button.
NOTE |
Restarting BricsCAD using a different user profile
Once you start using user profiles, you may need to copy, rename or delete them. Copying a profile is a quick way to create a new profile based on an existing profile.
Select the user profile you want to copy.
Click the Copy button.
The Copy Profile dialog displays.
Click the OK button to create the profile.
Select the user profile you want to rename.
Click the name of the selected user profile.
The Profile name field is active
now.
Type a new name in the Profile name field.
Click outside the Profile name field.
To edit the Description field:
Select the user profile you want to delete.
Click the Delete button.
Click the Yes button on the confirmation box to delete the profile.
NOTE |
The current profile cannot be deleted. |
To import a user profile from another user
When you import a user profile of another user all user dependent search paths (e. g. the local root and roamable root folders - see BricsCAD User Files) still refer to the other user, as a result the folders cannot be found and error messages such as "Unable to open program parameters file: default.pgp" might pop up when you start BricsCAD.
To correct this problem do the following:
On a Windows XP computer replace C:\\Documents and Settings\\username with %USERPROFILE%.
On a Windows Vista or Windows 7 computer replace C:\\Users\\username with %USERPROFILE%.
Use the Find/Replace procedure to quickly replace all references.
Save the user profile (*.arg)
Import the user profile.
Start BricsCAD using the imported profile.
The environment variable %USERPROFILE% will be replaced with:
NOTE |
Environment variables in profiles, using the %<variable_name>% format, are supported in V10.3.11. and higher. |
