Commands: OBJECTSCALE and SCALELISTEDIT
Annotation scales are used to calculate the scaling factor for annotative entities. It defines the height of annotative text entities or the overall scaling of annotative blocks. In general the annotation scale allows to create annotative entities in model space at the correct paper space size automatically.
Texts, MTexts, Dimensions, MLeaders: The current annotation scale is applied upon creation if the current style is annotative.
Hatches and Gradient Fills: The current annotation scale is applied if the HPANNOTATIVE system variable is ON.
Blocks: The current annotation scale defines the scaling of annotative blocks upon insertion.
Annotative entities can support multiple annotation
scales. When the SELECTIONPREVIEW
system variable is active or when using the Quad cursor menu,
an icon displays next to the highlighted entity indicating whether
a single annotation scale (
) applies to an annotative entity or multiple
To add or remove annotation scales to annotative entities
Use the following procedure to:
The Annotation Object Scale dialog displays.
NOTE |
Only scales that exist in the Scale List of the drawing are available. Use the SCALELISTEDIT command to edit the Scale List. |
