Draws the bottom half of a sphere as a 3D mesh surface.
command bar: ai_dish
menu bar: Model | Meshes | Dish
toolbar: Meshes |
: ai_dish
Center of dish: (Pick a point or enter coordinates.)
Set radius of dish or [Diameter]: (Pick a point, enter coordinates, or enter a value.)
Number of divisions around dish <16>: (Enter a number, or press Enter to keep the default value.)
Number of top-to-bottom divisions <8>: (Enter a number, or press Enter to keep the default value.)
Specifies the center point of the dish's open end; the end is drawn on the current x,y-plane. |
Specifies the radius of the dish. |
Changes the number of horizontal isolines used to simulate the dish's curved surface. |
Changes the number of vertical isolines from the default of 8. |
Specifies the diameter of the dish. Prompts you: Diameter of dish - specify the diameter by pointing or entering a value. |
Grips Editing
Mesh-formed dishes can be edited directly through grips:
Select the dish. Notice that it has several grips.
Drag a grip to stretch the adjacent faces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
