Draws a torus as a 3D mesh surface.
command bar: ai_torus
menu bar: Model | Meshes | Torus
toolbar: Meshes |
: ai_torus
Center of whole torus: <0,0,0> (Pick a point, or enter coordinates.)
Set Radius of whole torus or [Diameter]: (Specify the radius, or type D.)
Set radius of body of torus [Diameter]: (Specify the radius, or type D.)
Segments around body of torus <16>: (Type a value or press Enter to accept the default number.)
Segments around whole torus <16>: (Type a value or press Enter to accept the default number.)
Specifies the center of the torus; you can press Enter to accept the default coordinates. |
Specifies the overall radius of the torus; note that the distance is measured to the center of the tube (body). |
Specifies the radius of the torus body, or tube. It is not necessary for the body radius to be smaller than the whole radius. |
Specifies the diameters of the whole torus and/or body. |
Specifies the number of segments of the circles around the body of torus. |
Specifies the number of segments of the circles around the whole torus. |
Grips Editing
Mesh-formed torus surfaces can be edited directly through grips:
Select the torus. Notice that it has one grip at each vertex.
Drag the grip to move the adjacent faces.
Ai_Dish - draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
