Creates a polyline that forms a boundary inside a closed area through a dialog box.
command bar: boundary
aliases: bo, bpoly
menu bar: Draw | Boundary Polyline
toolbar: Draw | ![]()
: boundary
Choose options, and then click OK.
Boundaries |
Specifies the closed areas in which to place the boundary; temporarily dismisses the dialog box, and then prompts you at the command bar: Select a point to define a boundary or hatch area - pick a point inside a closed area. Notice that BricsCAD highlights draws the boundary, allowing you to preview it. The prompt repeats, allowing you to choose additional areas. When done selecting areas, press Enter: Select a point to define a boundary or hatch area - press Enter to return to the dialog box. |
Boundary Set |
Specifies where BricsCAD should search for entities that make up the boundary:
Creates a new selection set of entities that make up the boundary; temporarily dismisses the dialog box, and then prompts you at the command bar: Select entities - use any selection method to choose one or more entities. The prompt repeats, allowing you to choose additional entities. When done selecting entities, press Enter: Select entities - press Enter to return to the dialog box. |
Boundary Retention |
Polylines |
Islands |
When an area contains other areas, BricsCAD creates multiple boundaries. |
When an area contains other areas, BricsCAD creates a boundary of the outermost entities. |
When an area contains other areas, BricsCAD creates one boundary. |
Boundary Tolerance |
Specifies the largest gap BricsCAD ignores when creating a boundary inside an area that is not fully closed. |
Procedures
Grips Editing
Boundaries can be edited directly through grips:
Select the boundary. Notice that it has many grips.
Drag a grip to stretch the boundary.
BHatch and Hatch - place boundaries and hatch patterns through a dialog box.
-BHatch and -Hatch - places boundaries and hatch patterns through the command bar.
-Boundary - creates a polyline boundary inside closed areas through the command bar.
GenerateBoundary - Creates closed polylines from faces of 3D solids as well as the boundaries detected when the Enable Boundary Detection open of SELECTIONMODES is activated.
HatchGenerateBoundary - generates a boundary around a hatch or gradient fill.
Properties - changes the properties of boundaries.
Region - creates boundary-like regions.
Settings - specifies the default parameters for boundaries.
XEdges - creates 2D linear entities (lines, arcs, circles, ellipses, elliptical arcs and splines) from the edges of 3D solids, 3D solid faces, surfaces, etc. and regions.
