DrawOrder
Changes the display order of overlapping entities.
command bar:  draworder
alias:  dr
menu bar:  Tools | Draw Order
toolbar:  Draw Order |
: draworder
Select entities to change draw order: (Select one or more entities.)
Entities in set: 1
Select entities to change draw order: (Select one or more entities, or press Enter.)
Change draw order [Above/Under/Clear all orders/bring to Front/send to Back] <Send to back>: (Enter an option.)
Select Entities to Change Draw Order
Selects one or more entities; this command is meant to work with overlapping objects.
Above
Moves the entities above other entities, but not necessarily to the top (front) of display order.
Under
Moves the entities below other entities, but not necessarily to the bottom (back) of display order.
Clear all orders
Clears assigned display orders; entities are displayed as they were originally created.
The last created entity is displayed on top of one created earlier.
Bring to Front
Moves the entities' display order above all other entities.
Send to Back
Moves the entities' display order below all other entities.
Procedures
Adjusting the Draw Order
DrawOrderByLayer - sets draw order of overlapping objects through layer names.
HatchToBack - sets the draw order of all hatch entities in the drawing to display behind all other entities.
TextToFront - sets the draw order of all texts and dimensions in the drawing to display in front of all other entities.
BHatch and Hatch - set the draw order of hatch patterns relative to other entities through a dialog box.
-BHatch and -Hatch - set the draw order of hatch patterns relative to other entities through the command bar.
