EAttEdit
Edits the value and most properties of attributes, through a dialog box.
command bar:  eattedit
alias:  ate
menu bar:  Tools | Attributes | Edit Block Attributes
toolbar:  Attributes |
: eattedit
Select a block: (Choose a block that contains attribute data.)
Change properties, and then click OK.
Value
Edits the value of the attribute.
Select Block
Chooses another block.
Properties Tab
Layer
Specifies the layer name; choose one from the droplist.
Color
Specifies the color; choose one from the droplist.
Lineweight
Specifies the lineweight; choose one from the droplist.
Linetype
Specifies the linetype; choose one from the droplist.
Plot Style
Specifies the plot style; choose one from the droplist.
(Available only when plot styles are enabled in the drawing.)
Text Options Tab
Text Style
Specifies the text style name; choose one from the droplist.
Justification
Specifies the justification; choose one from the droplist.
Height
Specifies the height of the text.
Rotation
Specifies the rotation angle of the text.
Upside Down
Toggles whether the text is displayed upside down.
Backwards
Toggles whether the text is displayed backwards.
Width Factor
Specifies the width of the characters; use a value of less than 1.0 to squeeze text into a small space.
Oblique Angle
Specifies the slant of the characters; can be used to mimic italic text.
Procedures
Using the Attribute Editor
Editing attributes in the Properties bar
DdAtte - edits the values of attributes through a dialog box.
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
AttDisp - toggles the display of attribute text.
AttEdit - edits attribute values and properties.
-AttExt - extracts attributes from drawings to data files through the command bar.
AttRedef - redefines a block and updates associated attributes.
AttSync - synchronizes attribute definitions in all block references of a specified block definition.
BattMan - manages the attributes of a block definition.
Block and -Block - create blocks from attribute definitions and entities.
DataExtraction - exports entity properties, block attributes and drawing information to a an external file.
Explode - reduces attributes to tags.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
Properties - edits attribute values and properties.
RefEdit - edits blocks and attributes in-place.
