Toggles the frame around images.
command bar: imageframe
transparent: 'imageframe
menu bar: Modify | Raster Image | Display Image Frame
toolbar: Images | ![]()
: imageframe
Enter image frame setting <0>: (Type 0 or 1)
Left: Image frame on; right: image frame off. |
This command applies to all images in the drawing; frames cannot be toggled on individual images.
It also applies to the frames of rectangular and polygonal clippings.
When frames are turned off, images can only be selected using window selection.
Toggles the display of image frames:
-ImageAttach - attaches raster images to the drawing; displays prompts in the command bar.
ImageClip - clips images.
