Editing polyline vertices
Commands: PEDIT and PEDITEXT
The Edit vertices option of the Pedit command modifies individual polyline vertices.
When you select this option, the program switches into a special vertex editing mode and places an X on the first vertex. The X indicates the vertex you are editing. The Next and Previous options move the X to the next or previous vertex. You can edit only one vertex at a time.
When editing vertices, you can modify the polyline in the following ways:
The Peditext command is used in 2D Editing command group of the Quad cursor menu
Editing a polyline segment using the Quad
  1. Move the cursor over the polyline.
    If currently ON, the TIPS widget displays:
    The available commands in the Quad apply to the entire polyline.
  2. Press the Ctrl-key to switch to segment mode.
    The available commands in the Quad apply to the segment under the cursor.
  3. When the Quad cursor menu displays, do one of the following:
  4. Right click to execute the default Quad command.
  5. Move the cursor to the Quad and move to the Edit command group.
  1. Select a command:
  2. Add vertex: adds a vertex to the segment under the cursor.
  3. Add vertex at end: adds as a new vertex at the end of the polyline.
    This option is only available if the cursor is on one of the endpoints of a polyline.
  4. Adjust Bulge: Modifies the bulge factor of the segment under the cursor.
  5. Delete segment: deletes the segment under the cursor.
  6. Stretch segment: moves the segment under the cursor.
  7. Stretch vertex: moves the vertex closest to the cursor.
Starting the polyline vertex editing mode
  1. Do one of the following:
  2. Click the Edit Polyline tool button () on the Modify toolbar.
  3. Choose Edit Polyline in the Modify menu.
  4. Type editpline or pedit in the command window, then press Enter.
You are prompted: Select polyline to edit.
  1. Select the polyline.
    You are prompted: Edit polyline: Edit vertices/Close (or Open)/Decurve/Fit/Join/Linetype-Mode/Reverse/Spline/Taper/Width/Undo/<eXit>:
    A prompt menu displays.
  2. Choose Edit vertices in the prompt menu or type E and press Enter.
    You are prompted: Next/Previous/Angle/Break/Insert/Move/Regen/SElect/Straighten/Width/eXit/<Next>:
    The Editpline prompt menu changes:
A triangle indicates the start point of the polyline. The first vertex of the polyline is selected.
Convert a straight polyline segment into an arc
  1. Start the polyline vertex editing mode.
  2. Select the start vertex of the segment you want to convert.
    Choose Next vertex / Previous vertex  in the prompt menu to select a vertex.
    The X indicates the currently selected vertex.
  3. Choose Angle in the prompt menu or type A and press Enter.
    The prompt menu closes.
    You are prompted: Included angle for segment (>0 is ccw, 0 is straight, <0 is cw) <current angle>:
  4. Type a new included angle for the segment and press Enter.
    The direction of an arc segment is as follows:
  5. positive angles: counter clockwise
  6. negative angle: clockwise direction
  7. 0° for straight segments
  1. Choose Exit in the prompt menu or type X and press Enter to leave the Polyline vertex editing mode.
  2. Do one of the following:
  3. Continue editing the selected polyline.
  4. Choose Exit in the prompt menu or press Enter to conclude the Edit Polyline tool.
Break a polyline into two separate polylines
  2. Select the start vertex where you want to break the polyline.
  3. Choose Break in the prompt menu or type B and press Enter.
You are prompted: Next/Previous/Select/Go/eXit/<Next>:
The prompt menu changes:
  1. (option) Do one of the following  to select a second vertex:
  2. Choose Next vertex / Previous vertex  in the prompt menu.
  3. Choose Select in the prompt menu or type S and press Enter.
    You are prompted to select a vertex.
  1. Choose Go in the prompt menu or type G and press Enter.
    The polyline s broken into two polylines.
    If a second point is selected in step 4 the segment(s) between the selected vertices is (are) deleted.
  2. Choose Exit in the prompt menu or type X and press Enter to leave the Polyline vertex editing mode.
  3. Do one of the following:
  4. Continue editing the selected polyline.
  5. Choose Exit  in the prompt menu or press Enter to conclude the Edit Polyline tool.
Insert a new vertex in a polyline
  2. Select the start vertex of the segment where you want to insert a vertex.
  3. Choose Insert vertex in the prompt menu or type I and press Enter.
    You are prompted: Location for new vertex:
  4. Specify the location for the new vertex.
    The new vertex is inserted.
  5. Choose Exit in the prompt menu or type X and press Enter to leave the Polyline vertex editing mode.
  6. Do one of the following:
  7. Continue editing the selected polyline.
  8. Choose Exit in the prompt menu or press Enter to conclude the Edit Polyline tool.
Move a vertex in a polyline
  2. Select the vertex you want to move.
  3. Choose Move in the prompt menu or type M and press Enter.
    You are prompted: New location for vertex.
  4. Specify the new location for the selected vertex.
    The vertex is moved.
Delete vertices in a polyline
  2. Select the vertex before the first vertex you want to delete.
  3. Choose Straighten in the prompt menu or type S and press Enter.
    You are prompted: Straighten: Next/Previous/Select/Go/eXit/<Next>:
  4. Do one of the following to select the vertex after the last vertex you want to delete:
  5. Choose Next vertex / Previous vertex  in the prompt menu.
  6. Choose Select in the prompt menu or type S and press Enter.
    The vertices between the selected vertices are removed.
    A straight segment is drawn between the selected vertices.
Change the width of a polyline segment
  2. Select the start vertex of the segment you want to change the width of.
  3. Enter starting width <current width>:
  4. Do one of the following:
  5. Type the new width in the command bar and press Enter.
  6. Click to define the width graphically.
You are prompted: Enter ending width <current width>:
  2. Type the new width in the command bar and press Enter.
  3. Click to define the width graphically.
NOTE
The new width is applied when you conclude the Edit Polyline tool in step 6.
