mech:compdef-get-originalblock
(mech:compdef-get-originalblock  blkRefOrSolid)
Returns the original block definition ename for the component, referenced by the blkRefOrSolid (ename) entity.
Arguments
blkRefOrSolid (ename) the entity to query
Return
the ename of the BlockDefinition the referenced component is derived from;
returns NIL if the referenced component is the original BlockDefinition;
returns NIL in case of an error
Example
(vl-load-mech)  1
(setq blkRefOrSolid (entlast))
<Entity name: 400b3440>
(setq res (mech:compdef-get-originalblock blkRefOrSolid))
nil
Remarks
blkRefOrSolid could be a BlockReference or 3dSolid
Note
see function (mech:compdef-get-isoriginal)
©  Bricsys NV. All rights reserved.
