Works with Classic, Pro
Dimensions the radii of arcs and circles.
command bar: dimradius
alias: dimrad, dra
menu bar: Dimension | Radius
toolbar: Dimensions | Circles
: dimradius
Select arc or circle to dimension: (Choose an arc, polyline arc, or circle.)
Dimension text = \A1;%%c2.5806
Angle/Text/<Location of dimension line>: (Position the dimension, or enter an option.)
A circle with radius dimension placed outside
An arc with radius dimension placed inside
Chooses the arc, polyline arc, or circle to dimension. |
Locates the dimension leader line and text; drag the dimension around the entity, and inside or outside the entity. |
Changes the angle of the text. |
Changes the default text generated by Bricscad. |
Grips Editing
Radial dimensions can be edited directly through grips:
Select the radius dimension. Notice the grips.
Drag the grip on the circle to rotate the leader and text around the circle.
Drag the grip on the leader to relocate it and the associated text.
Drag the grip at the center of the circle to relocate the dimension anywhere in the drawing.
