Works with Classic, Pro
Changes the position of dimension text.
command bar: dimtedit
alias: dimted
menu bar: Dimension | Reposition Dimension Text
toolbar: Dimensions |
: dimtedit
Select dimension to reposition text: (Choose a dimension.)
Specify or enter text location: REstore/Angle/Left/Center/Right: (Drag the text to its new location, or enter an option.)
Chooses the dimension to edit. |
Resets the rotation angle to 0 degrees; does not change repositioned text. |
Rotates the dimension text. Prompts you: Angle of dimension text - specify the angle of the text; measured counter-clockwise from the positive x axis. |
Moves the text next to the left extension line. |
Centers the text between the two extension lines. |
