Associate data with a dialog box tile.
This function associates user-defined data with a dialog box tile. The key specifies the tile; key is a case-sensitive string. The data is a string that specifies the data, which can be referred as $data.
Tell me about...
Programming Overview of LISP (LISt Processing) Language
