Respond when the user clicks a dialog box tile.
This function assigns the expression to evaluate when the user selects the tile referenced by key. Both expression and key are strings; key is case-sensitive. Expression is typically another LISP function; key refers to the tile. This function operates on tiles that are user-selectable elements of a dialog box, such as radio buttons, check boxes, or buttons.
The expression refers to the tile, using the following arguments:
| Argument | Meaning |
| $value | Current value |
| $key | Tile name |
| $data | Application specific data |
| $reason | Callback reason |
| $x | Image x-coordinate |
| $y | Image y-coordinate |
Example
| Code | Returns |
| (action_tile "xpt" x_coord) | nil |
NOTES
Tell me about...
Programming Overview of DCL (Dialog Control Language)
Programming Overview of LISP (LISt Processing) Language
