Dismiss that dialog box.
This function terminates a dialog box. It returns the x,y coordinates of the dialog box's position, which can be used by the start_dialog function to place the dialog in the same position.
Flag is an alternative return code that is returned by the start_dialog function; you can use this flag for any purpose you desire. When flag has a value greater than 1, the value is returned by the start_dialog function. Otherwise, the start_dialog function returns as follows:
| Returns | Meaning |
| 0 | User clicked Cancel. |
| 1 | User clicked OK. |
Example
| Code | Returns |
| (done_dialog) | (0.000000 0.000000) |
Tell me about...
(new_dialog dialog dcl-id [function point])
Programming Overview of LISP (LISt Processing) Language
