Display a dialog box.
This is the function you use to display a dialog box. The dialog box is identified by dialog within the DCL file named dcl-id. The string dialog is obtained from the load_dialog function.
The new_dialog function optionally executes the LISP routine named function. To ignore this argument, use " "; you have to use the " " when you want to specify the point coordinates but not execute a function.
The optional point argument specifies the x,y coordinates of the upper-left corner. When point consists of negative coordinates, such as '(-1 -1), the dialog box appears at the default location, which is usually the center of the Bricscad window.
When the new_dialog function is successful, it returns T; otherwise, it returns nil.
Examples
| Code | Returns |
| (new_dialog "basicdcl" "sampler" "insert" '(1 2)) | T |
| (new_dialog "basicdcl" "sampler" " " '(-1 -1)) | T |
NOTE The order of calling a dialog box is as follows:
Tell me about...
Programming Overview of LISP (LISt Processing) Language
