(entmake [entity-list])
Add an entity to the drawing.
This function allows you to write the entity-list to the
database. The entity-list must be in the format, as shown by the entget function. Without a valid
entity-list, entmake doesn't make the entity and returns
nil.
Example
| Code |
Meaning: |
| (entmake |
| '((0 . "CIRCLE") |
Entity = circle |
| (62 . 5) |
Color = blue |
| (10 1.2 3.4 0.0) |
Center point = 1.2,3.4 |
| (40 . 5.6) |
Radius = 5.6 |
NOTES
- This function is similar to entmod. The difference is that
entmake allows you
to write a new list that was not previously in the database;
entmod creates a new entity by modifying an existing
entity.
- Entmake does not require that you provide
all information about the entity. Not required are dotted
pair data about the entity's properties when they do not differ
from default values: color, linetype, thickness, attributes-follow
flag, and the entity handle.
- While the data specified by entmake is very similar to DXF
format, there is one primary difference: x,y,z coordinates are
specified by entmake as a single value, rather than the
separate values in DXF. Thus, you specify group code 10 with
entmake, instead
of DXF group codes 10 (x-coordinate), 20
(y-coordinate), and 30 (z-coordinate).
Tell me about...
(entdel
entity-name)
(entget
entity-name [application-list])
(entlast)
(entmod
entity-list)
(entsel
[prompt])
(entupd
entity-name)
(nentsel
[prompt])
(nentselp
[prompt] [point])
LISP
Compatibility
Programming
Overview of LISP (LISt Processing) Language
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
