Redraw the entity.
This function redraws the entity on the screen. After you modify a block attribute or polyline vertex, the block or polyline is not updated automatically because recalculating and displaying a multitude of changes might take a long time.
Instead, you force an update of complex entities on the screen after the computations are done using entupd. The entity-name of an entity within the block or polyline updates the whole entity group.
Example
| Code | Meaning |
| (setq a (entnext)) | Assigns the entity-name to a. |
| . . . | Change entity-see the entmod function. |
| (entupd a) | Regenerates entity group, which contains a. |
NOTE You can ensure that all entities on the screen are updated with the (command"regen") function.
Tell me about...
(entget entity-name [application-list])
Programming Overview of LISP (LISt Processing) Language
