Ask the user to select an entity.
The entsel function selects a single entity using a point-click, and then returns a list containing the entity name and the coordinates of the point used to select it. Any prior entity snap settings have no effect unless specifically requested during the function.
If a prompt is supplied, the user will be asked to select the entity with the wording of that prompt. If no prompt is supplied, the default prompt "Select Entity:" is displayed.
Examples
| Code | Returns |
| (entsel) [pick an entity] |
Select entity: (<Entity name: 1ff0548> (5.0 5.0 0.0)) |
| (setq b (entsel "Select an line:")) [pick a line] |
Select an entity: (<Entity name: 1ff0564> (1.0 2.0 3.0)) |
NOTE The function entsel works only with top-level entities. To select entities that belong to a block or a polyline, use nentsel.
Tell me about...
(entget entity-name [application-list])
(setq symbol1 statement1 [symbol2 statement2] ...)
Programming Overview of LISP (LISt Processing) Language
