(findfile filename)
Find that file.
This function searches your computer for the location of a file. This is important because if you specify the name of a file in your LISP program that doesn't exist, you crash the program. When the file exists, its path and filename are returned; if it doesn't, the function returns nil.
Examples
Code Returns
(findfile "sampledwg.dwg") "c:\\icad\\sample\\sampledwg.dwg"
(findfile "junk.$$$") nil
Tell me about...
(getfiled title filename ext flags)
(load filename [flag])
(open filename mode)
(startapp appname [filename])
(xload appname [flag])
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
