Determine the value of the parameter.
This function returns data from the Bricscad/Bricscad/User section of the system registry. The parameter is a string with the following format:
"AppData/appname/sname/parameter" where:
| Cfg Name | Means |
| AppData | The [AppData] section. |
| appname | The name of the application. |
| sname | The section name. |
| parameter | The parameter name. |
Example
| Code | Returns |
| (getcfg "appdata/appname/sname/parameter") | 56 |
Tell me about...
Programming Overview of LISP (LISt Processing) Language
