Set the parameter to the value.
This function changes data in the [AppData] section of the Icad.Cfg file, if it exists. The value can be any text or number. The parameter is a string with the following format:
"AppData/appname/sname/parameter"
where:
| Cfg Name | Meaning |
| AppData | The [AppData] section. |
| appname | The name of the application. |
| sname | The section name. |
| parameter | The parameter name. |
Example
| Code | Returns |
| (setcfg "appdata/appname/sname/parameter" "56") | "56" |
Tell me about...
Programming Overview of LISP (LISt Processing) Language
