Make it a list.
This function creates a list from the expressions specified. You may also create the list literally by using the ' (quote) function, as shown in the last example below. Rather than use elements already defined as a list, you may need to create your own list. This list will become a variable, with its values preceded by the command list.
Examples
| Code | Returns |
| (setq b (list 1 2)) | (1 2) |
| (setq c (list "string1" "string2")) | ("string1" "string2") |
| (setq a (list (car b) (car c))) | (1 "string2") |
| (setq d '(1 2 "buckle my shoe")) | (1 2 "buckle my shoe") |
Tell me about...
(setq symbol1 statement1 [symbol2 statement2] ...)
Programming Overview of LISP (LISt Processing) Language
