Start processing a list box.
This function signals the start of processing a list key in a dialog box. The optional operation argument describes the list operation to be performed (default = 3):
| Operation | Meaning |
| 1 | Change contents of the list. |
| 2 | Append new data to the list. |
| 3 | Replace the list with a new one (default). |
The optional index argument is used only when operation = 1. It indicates the item # to be changed; the first item is #0; the second item is #1, and so on.
Examples
| Code | Comments |
| (start_list ssg) | Replace list with new list. |
| (start_list ssg 3) | Same action as above. |
| (start_list ssg 1 4) | Change the fifth item on the list. |
| (start_list ssg 2) | Add data to the list. |
NOTE You also use this function when creating list boxes and drop-down list boxes in DCL. For examples using this function in conjunction with DCL, see list_box and popup_list (drop-down list box).
Tell me about...
Programming Overview of DCL (Dialog Control Language)
Programming Overview of LISP (LISt Processing) Language
