Class AcadExternalReference
Member of BricscadDb
An instance of an external reference inserted into a drawing. To query or edit an existing external reference, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Document |
Copy | EffectiveName |
Delete | Handle |
GetAttributes | HasAttributes |
GetBoundingBox | HasExtensionDictionary |
GetExtensionDictionary | Hyperlinks |
GetXData | InsertionPoint |
Highlight | InsUnits |
IntersectWith | InsUnitsFactor |
Mirror | IsDynamicBlock |
Mirror3D | Linetype |
Move | LinetypeScale |
Rotate | Lineweight |
Rotate3D | Material * |
ScaleEntity | Name |
SetXData | Normal |
TransformBy | ObjectID |
Update | ObjectName |
OwnerID | |
Path | |
PlotStyleName | |
Rotation | |
TrueColor | |
Visible | |
XEffectiveScaleFactor | |
XScaleFactor | |
YEffectiveScaleFactor | |
YScaleFactor | |
ZEffectiveScaleFactor | |
ZScaleFactor |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
