Class AcadPViewport
Member of BricscadDb
The PViewport object represents a window that displays all or part of a drawing's paper space. To access the PViewport object, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | ArcSmoothness |
Copy | Center |
Delete | Clipped |
Display | CustomScale |
GetBoundingBox | Direction |
GetExtensionDictionary | DisplayLocked |
GetGridSpacing | Document |
GetSnapSpacing | GridOn |
GetXData | Handle |
Highlight | HasExtensionDictionary |
IntersectWith | Height |
Mirror | Hyperlinks |
LabelBlockId | |
Mirror3D | Layer |
Move | LensLength |
Rotate | Linetype |
Rotate3D | LinetypeScale |
ScaleEntity | Lineweight |
SetGridSpacing | Material |
SetSnapSpacing | ObjectID |
SetXData | ObjectName |
SyncModelView | OwnerID |
TransformBy | PlotStyleName |
Update | ShadePlot |
SheetView | |
SnapBasePoint | |
SnapOn | |
SnapRotationAngle | |
StandardScale | |
Target | |
TrueColor | |
TwistAngle | |
UCSIconAtOrigin | |
UCSIconOn | |
ViewportOn | |
Visible | |
VisualStyle | |
Width |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
