Class Acad3DSolid
Member of BricscadDb
To access the Solid3D object, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Centroid |
Boolean | Document |
CheckInterference | Handle |
Copy | HasExtensionDictionary |
Delete | History |
GetBoundingBox | Hyperlinks |
GetExtensionDictionary | Layer |
GetXData | Linetype |
Highlight | LinetypeScale |
IntersectWith | Lineweight |
Mirror | Material |
Mirror3D | MomentOfInertia |
Move | ObjectID |
Rotate | ObjectName |
Rotate3D | OwnerID |
ScaleEntity | PlotStyleName |
SectionSolid | Position |
SetXData | PrincipalDirections |
SliceSolid | PrincipalMoments |
TransformBy | ProductOfInertia |
Update | RadiiOfGiration |
ShowHistory | |
SolidType | |
TrueColor | |
Visible | |
Volume |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
