Revolve
Works with Pro
Revolves 2D closed entities to turn them into 3D solids.
command bar:  revolve
alias:  rev
menu bar:  Draw | 3D Entities | Revolve
toolbar:  Solids |
: revolve
Select entities: (Choose one or more closed 2D entities.)
Entities in set: 1
Select entities: (Choose more closed 2D entities, or press Enter to continue.)
Specify start point for axis of revolution or define axis by Object/Xaxis/Yaxis: (Enter an option.)
Specify angle of revolution <360>: (Enter the number of degrees, pick two points, or press Enter for the default.)
This command revolves only closed entities: circles, ellipses, closed polyline, closed splines, and regions.
The axis can be defined by two points; a line or a polyline segment; or the x or y axis.
The axis must be outside of the entity being revolved.
Select entities
Specifies the entities to be revolved.
The result is a 3D solid.
Specifies the axis of rotation.
Pick a point or enter x,y,z coordinates; prompts you:
Specify endpoint of axis - pick another point, or enter x,y,z coordinates.
The two points specify the endpoints of a line that forms the axis about which the 2D entity is revolved.
Object
Specifies the axis of rotation by an object.
Pick a line or a polyline segment.
Xaxis
Uses the x axis as the axis of rotation.
Yaxis
Uses the y axis as the axis of rotation.
Specifies the angle through which the entity should be revolved.
Enter any angle larger than 0 degrees, or one of the following standard angles:
  • 90 - revolves the entity 1/4 of the way around the axis of rotation.
  • 180 - revolves the entity 1/2 of the way around.
  • 270 - revolves the entity 3/4 of the way around.
  • 360 - revolves the entity all the way around.
Press Enter to accept the default of 360 degrees.
