Annotation Scales
Commands: OBJECTSCALE and SCALELISTEDIT
Annotation scales are used to calculate the scaling factor for annotative entities. It defines the height of annotative text entities or the overall scaling of annotative blocks. In general the annotation scale allows to create annotative entities in model space at the correct paper space size automatically.
 Annotative entities can support multiple annotation scales. When the SELECTIONPREVIEW system variable is active or when using the Quad cursor menu, an icon displays next to the highlighted entity indicating whether a single annotation scale () applies to an annotative entity or multiple ().
To add or remove annotation scales to annotative entities
Use the following procedure to:
  1. Select the annotative entity or entities.
  2. In the Properties Bar, select the Annotative Scale field.
  3. Click the Browse button () of the Annotative Scale field.
The Annotation Object Scale dialog displays.
  1. (option) If multiple entities were selected, choose whether to list all scales for the selection or the common scales only.
  2. (Optional) Führen Sie einen der folgenden Schritte aus:
  3. Select one or more scales in the list, then click the Delete button.
    The selected scale(s) are removed from the list.
  4. Click the Add... button, then select one or more scales in the list and click the OK button.
    The selected scale(s) are added are added to the list.
  1. Click the OK button to close the Annotation Object Scale dialog.
    The changes are applied to the selection set.
ANMERKUNG
Only scales that exist in the Scale List of the drawing are available. Use the SCALELISTEDIT command to edit the Scale List.
