PDF export takes plot style tables into account.
MTEXT EDITOR: Support for fields and a new buttons to convert text from uppercase to lowercase and vice versa.
The new FIELDEVAL system variable controls when fields in multiline texts are updated automatically .
HOT GRIPS: multiple grip point modifications.
Context menu or command line entry for cycling through STRETCH, SCALE, MOVE, MIRROR and ROTATE commands during grips editing.
New dialogs for BLOCK and WBLOCK commands: options to control the Insert Unit of the block and Allow Explode property.
FROM entity snap option.
Associative dimensions: support for Intersection, Apparent Intersection and Perpendicular entity snap points.
Support for MrSID raster image files.
SELECTIONPREVIEW and PREVIEWEFFECT system variables control the highlighting of entities when the cursor hovers over them.
PREVIEWFILTER system variable controls which entity types are excluded from selection previewing.
ENTITY SELECTION: Cycling through overlapping entities during selection.
POLAR SNAP: Additional tracking path, parallel to the Z-axis of the current UCS is available in 3D views.
PAN: Real-time panning is now smooth and flicker-free, not matter what the size of the drawing is.
GRADIENT: Creates gradient hatches in one or two colors and nine different patterns.
FIELD: In multiline texts you can use fields to insert a wide range of variables, such as date and time, drawing properties, plot settings, hyperlinks and user defined variables.
UPDATEFIELD: Forces the explicit update of field variables.
PASTEORIG: Pastes entities at their original location.
SECURITYOPTIONS: Sets or removes a password on the drawing.
DIMARC: Creates Arc Length dimensions.
ETRANSMIT: Lists dependencies of a drawing: external references, image references, plot configuration files, plot style tables, font map files. Allows to package the drawing and all or a selection of the dependent files in a ZIP file or a folder.
eBridge To Vondle allows to upload the drawing and all or a selection of its dependent files to a Vondle project.
(*) Some features or commands might not be available yet on the Linux platform. Please check the Command Reference guide.
