Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Edits block references and externally-referenced drawings through a dialog box (short for "reference editor").
command bar: refedit
transparent: 'refedit
toolbar: Ref Edit |
: refedit
Select reference: (Choose a block or an xref.)
Choose options, and then click OK.
Use REFCLOSE or the Refedit toolbar to end reference editing session.
Make changes to the reference, and then use the RefClose command to save the changes.
Chooses the reference to edit. Pick a single block or externally-referenced drawing. Only one reference can be edited at a time. |
Dialog Box |
Lists the name of the block and nested blocks, if any. |
Determines how nested blocks/xrefs are handled. |
Automatically |
Nested entities are included automatically. |
Prompt |
Nested entities can be selected manually. After clicking OK to close this dialog box, you are prompted in the command bar: Select nested objects - select one or more nested entities. Select nested objects - select more nested entities, or press Enter to continue. |
Determines how entities are treated during editing. |
Enable unique layer and symbol names |
Toggles the use of $0$ in layer and other names: Yes - prefixes names with filename$0$. No - does not prefix names. |
Display attribute definitions for editing |
Toggles the inclusion of attributes: Yes - attribute definitions can be edited; attribute values are invisible. No - attributes are unavailable for editing. Modified attribute definitions do not affect existing insertions; they come into effect with insertions made from now on. |
Lock objects not in working set |
Toggles locking of entities not being edited: Yes - locks entities outside the reference being edited. No - does not lock other entities. Locked entities can be seen but not edited. |
-RefEdit - edits references in-place through the command bar.
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
AttDisp - toggles the display of attribute text.
DdAtte - edits the values of attributes through a dialog box.
Block and -Block - create blocks from attribute definitions and entities.
EAttEdit - edits attribute values and most properties.
Explode - reduces blocks to constituent entities and attributes to tags.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
Properties - edits block and attribute values and properties.
