Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Edits the value and most properties of attributes, through a dialog box.
command bar: eattedit
alias: ate
menu bar: Tools | Edit Block Attributes
toolbar: Tools | ![]()
: eattedit
Select a block: (Choose a block that contains attribute data.)
Change properties, and then click OK.
Edits the value of the attribute. |
Chooses another block. |
Specifies the layer name; choose one from the droplist. |
Specifies the color; choose one from the droplist. |
Specifies the lineweight; choose one from the droplist. |
Specifies the linetype; choose one from the droplist. |
Specifies the plot style; choose one from the droplist. (Available only when plot styles are enabled in the drawing.) |
Specifies the text style name; choose one from the droplist. |
Specifies the justification; choose one from the droplist. |
Specifies the height of the text. |
Specifies the rotation angle of the text. |
Toggles whether the text is displayed upside down. |
Toggles whether the text is displayed backwards. |
Specifies the width of the characters; use a value of less than 1.0 to squeeze text into a small space. |
Specifies the slant of the characters; can be used to mimic italic text. |
DdAtte - edits the values of attributes through a dialog box.
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
AttDisp - toggles the display of attribute text.
AttEdit - edits attribute values and properties.
AttExt - extracts attributes from drawings to data files through a dialog box.
-AttExt - extracts attributes from drawings to data files through the command bar.
Block and -Block - create blocks from attribute definitions and entities.
Explode - reduces attributes to tags.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
Properties - edits attribute values and properties.
RefEdit - edits blocks and attributes in-place.
