Class AcadBlock
Member of BricscadDb
The Block object represents one or more entities grouped together to create a single entity. The Block definition contains a name and a set of entities. To insert a block into a drawing, use the InsertBlock method. To edit or query a block definition, use the following methods and properties:
| Methods | Properties |
| Add3DFace | Application |
| Add3DMesh | BlockScaling |
| Add3DPoly | Comments |
| AddArc | Count |
| AddAttribute | Document |
| AddBox | Explodable |
| AddCircle | Handle |
| AddCone | HasExtensionDictionary |
| AddCylinder | IsDynamicBlock |
| AddDim3PointAngular | IsLayout |
| AddDimAligned | IsXRef |
| AddDimAngular | Layout |
| AddDimDiametric | Name |
| AddDimOrdinate | ObjectID |
| AddDimRadial | ObjectName |
| AddDimRotated | Origin |
| AddEllipse | OwnerID |
| AddHatch | Path |
| AddImage | Units |
| AddLeader | XRefDatabase |
| AddLightWeightPolyline | |
| AddLine | |
| AddMText | |
| AddPoint | |
| AddPolyfaceMesh | |
| AddPolyline | |
| AddRay | |
| AddRegion | |
| AddRevolvedSolid | |
| AddSection | |
| AddShape | |
| AddSolid | |
| AddSphere | |
| AddSpline | |
| AddTable | |
| AddText | |
| AddTolerance | |
| AddTorus | |
| AddTrace | |
| AddWedge | |
| AddXLine | |
| AttachExternalReference | |
| Bind | |
| Delete | |
| Detach | |
| GetExtensionDictionary | |
| GetXData | |
| InsertBlock | |
| Item | |
| Reload | |
| SetXData | |
| Unload | |
| WBlock |
