Class AcadLeader
Member of BricscadDb
The Leader object represents a line leading from a feature of the drawing to an annotation, such as a dimension. To create a leader, use the AddLeader method. To access the Leader object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Annotation |
| ArrayRectangular | Application |
| Copy | Color |
| Delete | Coordinates |
| Erase | Document |
| GetBoundingBox | EntityName |
| GetExtensionDictionary | |
| GetXData | Handle |
| Highlight | HasExtensionDictionary |
| IntersectWith | Hyperlinks |
| Mirror | Layer |
| Mirror3D | Linetype |
| Move | LinetypeScale |
| Rotate | Lineweight |
| Rotate3D | Normal |
| ScaleEntity | Parent |
| SetXData | PlotStyleName |
| TransformBy | StyleName |
| Update | TrueColor |
| Type | |
| VerticalTextPosition | |
| Visible |
