Property Normal As Vector
Specifies or returns the x, y, and z coordinates of the normal direction vector for the entity.
Syntax
where:
objectVariable Variant (three-element array of doubles) representing a 3D normal unit vector in WCS;
object is the applicable entity object;
applies to following objects:
Arc, Attribute, AttributeReference, BlockRef, Circle, Dim3PointAngular, DimAligned, DimAngular, DimArcLength, DimDiametric, DimOrdinate, DimRadial, DimRadialLarge, DimRotated, Ellipse, ExternalReference, Hatch, Leader, LightweightPolyline, Line , MInsertBlock, MText, Point, Polyline, Region, Section, Shape, Solid, Text, Tolerance, Trace.
Examples...
