Class AcadMText
Member of BricscadDb
The MText object represents multi-line text, or a paragraph of characters that fits within a boundary. To create an MText object, use the AddMText or method. To modify or obtain information about a point entity, use the following methods and properties:
| Methods | Properties | Events |
| ArrayPolar | Application | Modified |
| ArrayRectangular | AttachmentPoint | |
| Copy | BackgroundFill | |
| Delete | Document | |
| GetBoundingBox | DrawingDirection | |
| GetExtensionDictionary | Handle | |
| GetXData | HasExtensionDictionary | |
| Highlight | Height | |
| IntersectWith | Hyperlinks | |
| Mirror | InsertionPoint | |
| Mirror3D | Layer | |
| Move | Linetype | |
| Rotate | LinetypeScale | |
| Rotate3D | Lineweight | |
| ScaleEntity | Normal | |
| SetXData | Parent | |
| TransformBy | PlotStyleName | |
| Update | Rotation | |
| StyleName | ||
| TextString | ||
| Visible | ||
| Width |
