Class AcadPViewport
Member of BricscadDb
The PViewport object represents a window that displays all or part of a drawing's paper space. To access the PViewport object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | ArcSmoothness |
| Copy | Center |
| Delete | Clipped |
| Display | CustomScale |
| GetBoundingBox | Direction |
| GetExtensionDictionary | DisplayLocked |
| GetGridSpacing | Document |
| GetSnapSpacing | GridOn |
| GetXData | Handle |
| Highlight | HasExtensionDictionary |
| IntersectWith | Height |
| Mirror | Hyperlinks |
| LabelBlockId | |
| Mirror3D | Layer |
| Move | LensLength |
| Rotate | Linetype |
| Rotate3D | LinetypeScale |
| ScaleEntity | Lineweight |
| SetGridSpacing | Material |
| SetSnapSpacing | ObjectID |
| SetXData | ObjectName |
| SyncModelView | OwnerID |
| TransformBy | PlotStyleName |
| Update | ShadePlot |
| SheetView | |
| SnapBasePoint | |
| SnapOn | |
| SnapRotationAngle | |
| StandardScale | |
| Target | |
| TrueColor | |
| TwistAngle | |
| UCSIconAtOrigin | |
| UCSIconOn | |
| ViewportOn | |
| Visible | |
| VisualStyle | |
| Width |
