Class AcadPolyfaceMesh
Member of BricscadDb
The PolyfaceMesh object is a 3D mesh consisting of a series of connected polygon faces. To create a PolyfaceMesh object, use the AddPolyfaceMesh method. To access a PolyfaceMesh object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | Coordinate |
| Copy | Coordinates |
| Delete | Document |
| GetBoundingBox | Handle |
| GetExtensionDictionary | HasExtensionDictionary |
| GetWidth | Hyperlinks |
| GetXData | Layer |
| Highlight | Linetype |
| IntersectWith | LinetypeScale |
| Mirror | Lineweight |
| Mirror3D | Material |
| Move | NumberOfFaces |
| Offset | NumberOfVertices |
| Rotate | ObjectID |
| Rotate3D | ObjectName |
| ScaleEntity | OwnerID |
| SetXData | PlotStyleName |
| TransformBy | TrueColor |
| Update | Visible |
