Class Acad3DSolid
Member of BricscadDb
To access the Solid3D object, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | Centroid |
| Boolean | Document |
| CheckInterference | Handle |
| Copy | HasExtensionDictionary |
| Delete | History |
| GetBoundingBox | Hyperlinks |
| GetExtensionDictionary | Layer |
| GetXData | Linetype |
| Highlight | LinetypeScale |
| IntersectWith | Lineweight |
| Mirror | Material |
| Mirror3D | MomentOfInertia |
| Move | ObjectID |
| Rotate | ObjectName |
| Rotate3D | OwnerID |
| ScaleEntity | PlotStyleName |
| SectionSolid | Position |
| SetXData | PrincipalDirections |
| SliceSolid | PrincipalMoments |
| TransformBy | ProductOfInertia |
| Update | RadiiOfGiration |
| ShowHistory | |
| SolidType | |
| TrueColor | |
| Visible | |
| Volume |
