Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Draws dimensions parallel to (aligned with) selected entities; works with lines, polylines, arcs, and circles.
command bar: dimaligned
alias: dal, dimali
menu bar: Dimension | Aligned
toolbar: Dimensions |
: dimaligned
ENTER to select entity/<Origin of first extension line>: (Press Enter to dimension an entity.)
Select entity to dimension: (Select a line, polyline, arc, or circle.)
Angle/Text/<Location of dimension line>: (Pick a point to locate the dimension line away from the entity.)
Dimension text = \A1;3.7504
: dimaligned
ENTER to select entity/<Origin of first extension line>: (Choose a point to locate the first extension line.)
Origin of second extension line: (Choose a second point to locate the second extension line.)
Angle/Text/<Location of dimension line>: (Pick a point to locate the dimension line.)
Dimension text = \A1;1.3535
Press Enter to dimension a single entity. |
Specifies the line, polyline, arc, or circle to dimension; other entities cannot be dimensioned with this option. |
Locates the dimension line away from the entity; determines the length of the extension lines. |
Specifies the angle of the text; useful for keeping text horizontal with inclined dimension lines. |
Specifies the text; useful for overriding the default measurement generated by Bricscad. |
Specifies the origin of the first extension line. |
Specifies the origin of the second extension line. |
Grips Editing
Aligned dimensions can be edited directly through grips:
Select the aligned dimension. Notice the grips.
Drag either grip on the dimension line to move the dimension line.
Drag the grip on the text to relocate it.
Drag either grip on extension lines to rotate and stretch the dimension.
Move the dimension line by dragging either grip near the arrowhead:
Relocate the text and dimension line by dragging the grip centered on the dimension line (the leader is added automatically, if required):
Rotate and stretch the dimension by dragging either grip located at the base of the extension lines:
