Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Draw leaders.
command bar: leader
aliases: le, lead
: leader
Start of leader: (Pick a point.)
Next point: (Pick another point.)
To point: Format/Undo/<Annotation>: (Enter an option, or pick another point.)
First line of annotation text <options>: (Enter text, or type O.)
Next line of annotation text: (Press Enter to exit command.)
Leaders consist of the following parts:
Specifies the starting point of the leader line. Pick a point or enter x,y coordinates. To place the leader accurately, use entity snaps. An arrowhead is placed at the starting point automatically. |
Specifies the first vertex of the leader line. |
Specifies the next vertex, or the endpoint of the leader line. |
Specifies the leader style; prompts you: Arrow/None/SPline/STraight/<Exit> - enter an option. |
Arrow |
Draws an arrowhead at the leader's start point (default). |
None |
Draws no arrowhead.
SPline |
Draws the leader as a spline.
STraight |
Draws the leader as straight line segments (default). |
Exit |
Returns to the previous prompt. |
Undoes the last leader line segment. |
Starts adding text to the end of the leader line. The leader can have one or more lines of text.
Caution: the annotation is independent of the leader line; when moving a leader, be sure to include the annotation in the selection set. |
Specifies the first line of text. For no text, press Enter instead of entering text. |
Specifies the second line of text. |
Specifies the type of annotation. Do not enter "O" to access this option; press Enter only; prompts you: Dimension text options: Block/Copy/None/Tolerance/<Mtext> - enter an option. |
Block |
Uses a block as the annotation; displays prompts identical to that of the -Insert command: ? to list blocks in drawing/~ to open the file dialog/<Block to insert> - enter an option. See -Insert command for details on these options. |
Copy |
Uses any other entity in the drawing as the annotation; prompts you: Select an entity - choose an entity, other than the leader itself. |
None |
The annotation is kept blank. |
Tolerance |
Uses tolerance notation for the annotation; displays the Geometric Tolerance dialog box.
See Tolerance command. |
Mtext |
Uses mtext (multi-line text) for the annotation; displays the Multiline Text dialog box. See MText command. |
DimLeader - places leaders with text, blocks, entities, or tolerances.
