Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Inserts a PDF file as an underlay into the current drawing.
command bar: pdfattach
menu bar: Insert | Attach Pdf...
: pdfattach
Displays the Select PDF Underlay dialog window.
Select a PDF file, then click Open.
Bricscad displays a dialog box:
Specifies the name of the attached PDF file. If more than one PDF file has been attached to the drawing, their names are listed by the droplist. |
Browse |
Displays the Select PDF Underlay dialog window. Choose a PDF file, and then click Open. |
Click the droplist to choose a different path type:
Specifies the location of the underlay's lower-left corner. |
Specify On-screen |
Determines when the insertion point is specified:
Insertion point for block - pick a point or enter x,y,z coordinates.
X Y Z |
Specifies the x,y,z coordinates for the underlay's insertion point. Use 0,0,0 to insert the underlay at the drawing's origin. |
Specifies the size of the PDF underlay. |
Specify On-screen |
Determines when the scale factors are specified:
Corner/XYZ/X scale factor - enter an option, pick two points a number, or press Enter for the default value. Y scale factor: < Equal to X scale> - enter an option, a number, or press Enter for the default value
X Y Z |
Specifies the scale factors of the underlay in the x, y, and z directions. Use 1,1,1 to keep the underlay at its original size. |
Specifies the rotation angle of the PDF underlay. |
Specify On-screen |
Determines when the rotation angle is specified:
Rotation angle for block - enter a number, pick two points, or press Enter for the default value.
Angle |
Specifies the rotation angle about the insertion point. Positive angles rotate the underlay counterclockwise. Use 0 to keep the underlay at it original orientation. |
Pdfclip - allows clipping of PDF underlays.
Pdflayers - allows to control the display of layers in a PDF underlay.
XRef - attaches and controls externally referenced drawings through the Drawing Explorer.
-XRef - attaches and controls xrefs through the command bar.
XClip - clips externally-referenced drawings.
Insert - inserts drawings as blocks.
