Class Acad3DFace
Member of BricscadDb
The Face3D object represents a 3D triangle or quadrilateral plane section. To create a 3D face, use the Add3DFace method. To edit or query a 3D Face, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Color |
Copy | Coordinates |
Delete | Document |
Erase | EntityName |
GetBoundingBox | |
GetExtensionDictionary | Handle |
GetInvisibleEdge | HasExtensionDictionary |
GetXData | Hyperlinks |
Highlight | Layer |
IntersectWith | Linetype |
Mirror | LinetypeScale |
Mirror3D | Lineweight |
Move | Parent |
Rotate | PlotStyleName |
Rotate3D | VisibilityEdge1 |
ScaleEntity | VisibilityEdge2 |
SetXData | VisibilityEdge3 |
SetInvisibleEdge | VisibilityEdge4 |
TransformBy | Visible |
Update | |
© Menhirs NV. All rights reserved. |
